> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/ssms-add-on-entry-password-injection-not-supported-for-version-18-and-later.md).
# SSMS add-on entry password injection not supported for version 18 and later
Understand why password injection for the SSMS add-on entry stops working in Remote Desktop Manager once you upgrade to SSMS 18 or later.
The SSMS Add-on entry in Remote Desktop Manager uses command-line arguments to launch SSMS and pre-fill the authentication details, including the username and password. However, Microsoft removed support for password injection via command-line arguments in SSMS 18 as part of their security enhancements.
For users who rely on credential injection in Remote Desktop Manager, this change introduces an extra step when launching SSMS connections. If you are using SSMS version 17 or earlier, password injection will still work as expected. However, once you upgrade to ***SSMS 18 or higher***, you must manually enter your password.
*"Please note that SQL Server Management Studio version 18 or higher will not work when supplying the password. Do you wish to continue anyway?"*
GET https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/ssms-add-on-entry-password-injection-not-supported-for-version-18-and-later.md?ask=<question>&goal=<user_goal>
