Skip to content
SQL Server always on availability groups
The primary Remote Desktop Manager and Devolutions Server clients are built using the .NET platform. Therefore, their database-related capabilities often depend on the underlying .NET libraries.
Consequently, supported availability groups depend on the features provided by the database driver itself. The following types are all supported:
  • Application intent
  • Multi-subnet failover
  • Multi-subnet failover: faster single subnet endpoint failover
  • Multi-subnet failover: named instance resolution for SQL clustered instances
  • Read-only routing
Last updated
Was this helpful?
