Salesforce Cloud dashboard entry settings
The Salesforce Cloud dashboard entry allows for a centralized and streamlined management of your Salesforce threads without leaving Remote Desktop Manager Windows. Dashboard users can search for specific cases, filter for those to which they are assigned, open cases, and create threads and new messages, and much more.
Every field of the Salesforce Cloud dashboard entry is described below.
Login URL
Set the Login URL for the Salesforce account, which changes depending on the environment, i.e., production or test.
Client ID
Enter your Salesforce Client ID. This information can be found in the API (Enable OAuth Settings) section in Salesforce.
Client Secret
Enter your Salesforce Client Secret. This information can be found in the API (Enable OAuth Settings) section in Salesforce.
User password
Enter your Salesforce user password.
Security token
Enter your Salesforce security token.
Last updated
Was this helpful?
