Protocol handler
A Protocol handler has been implemented in Remote Desktop Manager to be able to launch a session directly from HTML content. This can be very useful to call Remote Desktop Manager from a Configuration Management Database (CMDB) or even a Document Management System (DMS).
Scenarios
There are two ways to use the handler:
Generating a URL for a session: basically every entry type that connects to a remote device using a protocol.
Generating a URL for a template: allows you to specify the host name of the device you wish to connect to, but takes the settings of the template.
Parameters
Here are the parameters used to build a protocol handler URL for advanced scenarios. DataSource and Session IDs are enough to open a connection.
DataSource
Indicate the workspace or the database ID. Find them in the IDs section of the Advanced properties of an entry. A workspace ID is unique per installation, which makes the URL usable only by the workstation where the workspace has been created. By default, Remote Desktop Manager generates the URL with the database ID.
Session
Indicate the ID of a session. Find it in the Session ID field in the Advanced properties of a session.
Template
Indicate the ID of the template of an entry. The template parameter retrieves some properties of a template and uses them against the session parameter. The host parameter is required when using the template parameter.
Host
Indicate the hostname or IP address of the remote device. Used along with the template parameter, or to override the host property of the session parameter.
Port
Indicate the port to use. Used to override the port property of the session or template parameter.
Username
Indicate the username to use. Used to override the username property of the session or template parameter.
Password
Indicate the password to use. Used to override the password property of the session or template parameter.
Domain
Indicate the domain to use. Used to override the domain property of the session or template parameter.
Title
Indicate the title of the tab when a session is launched using the Embedded (tabbed) display mode. This can be very useful when several sessions are launched at the same time.
Filter
Populate the Search field.
Tabpage
Give the focus to a tab in the dashboard after the application has completed the startup procedure. Available only with the Select action. The possible tabs are:- Overview
Documentation
Macros/Scripts/Tools
Management Tools
Information
Logs
Recordings |
Actions
Open: Open the specified connection.
Find: Find sessions by host.
Edit: Edit the specified connection.
View: View the password of the specified entry.
OpenWithMacro: Open the specified with a macro.
Select: Select a connection in the navigation pane (allows to select a tab in the dashboard as well).
Syntax
rdm://<action>=<value>[&=<value>]
The base syntax of the protocol handler requires the application protocol, an action and at least one parameter to work with.
There are three rules to follow when constructing an URL for the protocol handler:
The action is separated from the parameters with a question mark (?).
Each parameter is assigned a value by using an equal sign (=).
Parameter/Value pairs are separated with an ampersand (&).
Examples
Open Remote Desktop Manager with the search/filter field populated and the focus on the Dashboard
rdm://open?Filter=RDP&Tabpage=Dashboard
Open an RDP session
In the Entry information section of an entry's properties, click on Create web Url.
Select RDM protocol handler (rdm://).
The URL has now been copied to the clipboard. Click OK to close the confirmation window.
Paste (Ctrl+V) this URL in any application able to handle application protocols. It can be in a web page, a web browser address bar, or even a supported chat application. The protocol handler launches Remote Desktop Manager if it is closed, then performs the requested action with the provided parameters.
Last updated
Was this helpful?
