> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/password-strength-rating.md).
# Password strength rating
Understand how Remote Desktop Manager converts Zxcvbn password scores into strength labels shown in the password generator and security analyzer reports.
Remote Desktop Manager's [***Password generator***](/rdm/ribbon-menu-bar/tools/password-generator.md) tool as well as reports such as the [***Entry security analyzer***](/rdm/ribbon-menu-bar/reports/entry-security-analyzer.md) and the ***Password analyzer*** provide feedback about existing and generated passwords.
This feedback incorporates a password rating score, assessed through [Zxcvbn](https://lowe.github.io/tryzxcvbn/). The score, represented as a numerical value, is subsequently converted into a strength label, which is what Remote Desktop Manager displays. The numerical score can be accessed by exporting the ***Entry security analyzer*** into any file format (CSV, Html, Xlsx, or Xml).
Consult the table below to identify the corresponding strength label for each numerical score range.
| Strength label   | Score / score range                |
| Encrypted        | Less than or equal to -10          |
| None             | -1                                 |
| Popular Password | 1                                  |
| Forbidden        | 2                                  |
| Very Weak        | Less than 20                       |
| Weak             | Less than 40                       |
| Good             | Less than 60                       |
| Strong           | Less than 80                       |
| Very Strong      | Less than 100                      |
| Perfect          | Anything else (cannot be achieved) |
#### See also
* [Devolutions Academy – Building and managing reports](https://academy.devolutions.net/student/activity/3380519)
* [Devolutions Academy – Built-in generators: passwords, certificates, ports, and network scan](https://academy.devolutions.net/student/activity/3381288)
GET https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/password-strength-rating.md?ask=<question>&goal=<endgoal>
