Multiple checkouts
The Multiple checkouts setting in Remote Desktop Manager allows multiple users to check out and edit the same entries simultaneously. To do so, go into the properties of an entry, folder, root folder, or Vault settings and navigate to Security settings – Multiple checkouts.
OPTION
DESCRIPTION
Default
Uses the Multiple checkouts setting from the Vault settings.
Inherited
Inherits the checkout setting from a parent.
Off
Disables Multiple checkouts.
Infinite
Allows users to check out the same entry simultaneously without restriction.
Custom
Lets you define the maximum number of users who can check out an entry at the same time.
Root
Uses the Multiple checkouts defined on the root object only, ignoring intermediate parent.
Last updated
Was this helpful?
