Move permission
The permission Move permission on entries in Remote Desktop Manager can be configured on your vault or in your entries and it is enabled by default.
To move an entry, in addition to Move permission on entries, you also require:
Edit the "source" entry
Add in the destination
Move on the "source" entry
This means you can configure a user to have the permission to edit an entry, but deny them the right to move it.
Last updated
Was this helpful?
