Manage custom variables
Remote Desktop Manager has lists of all custom variables, which can be created, modified, or deleted in three different locations depending on their intended use.
In File – Settings – Applications – Custom variables: each custom variable requires at least a Name and a Value. These are user-specific and can be used in all workspaces.
In Administration – Vault settings – View – Variables: each custom variable requires at least a Name, a Value, and a Description. All users that have access to the Vault settings may see and use them, but they can only be used in that specific vault.
In Administration – System settings – Common – Custom variables: each custom variable requires at least a Name, a Value, and a Description. All users that have access to the Vault settings may see and use them, but they can only be used in the specific workspace.
See also
Last updated
Was this helpful?
