Macro parameters
Parameters are available for Command line (External Application), Command line (Macros/Scripts/Tools), Windows terminal, and Typing macros (Macros/Scripts/Tools) entries.
Text: Parameters that allow input of standard text.
Secured: Parameters designed to handle sensitive information securely, hiding input from view.
View Command: View the command from the General section.
Prompt for parameters on open: If this option is enabled, the parameters will be displayed each time the macro is executed.
Last updated
Was this helpful?
