Local color coding
Remote Desktop Manager allows users to mark entries using colored categories. These categories help classify entries at a glance, improving navigation and identification.
Select an entry and click Edit – Local color coding – Manage.
SETTINGS
DESCRIPTIONS
Add a category
Create a new category and assign a custom color (custom or web).
Remove a category
Delete the category.
Edit a category
Select a category to change the color using the color drop-down list or modify the category name.
Reorder a category
Click the up/down arrow buttons to adjust the order of categories.
Last updated
Was this helpful?
