Skip to content
Import credentials
Remote Desktop Manager imports credentials from 16 third-party applications. It is an efficient way to build your data. The imported information can be converted into different types of entry (e.g. username/password, Login (account), and Website).
You can use credential entries to open remote connections, saved as sessions in Remote Desktop Manager. Credential repositories link one credential or a list of credentials with a session.
To see the types of information you can import, go to File – Import.
Learn More
Watch this video for step-by-step instructions: Import credentials from KeePass.
Last updated
Was this helpful?
