> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/deprecated-workspaces.md).
# Deprecated workspaces
A deprecated workspace refers to a workspace that is no longer recommended or officially supported, primarily for security reasons.
{% tabs %}
{% tab title="Windows" %}
### Show deprecated workspaces
Follow this quick step-by-step guide to show deprecated workspace types.
1. Click on ***File – Settings – Types – Sessions***.
2. Check ***Show deprecated workspace types***.
3. Click ***Save***.
   {% endtab %}
{% tab title="macOS" %}
### List of deprecated workspaces
Here is the current list of deprecated workspaces:
* Microsoft Azure SQL
* Microsoft SQL Server
1. Add a new workspace.
2. Click ***Show deprecated workspace types*** in the bottom-left corner of the window.
   {% endtab %}
{% tab title="Linux" %}
   {% endtab %}
{% tab title="Android" %}
### Migrating to Devolutions Cloud
Workspaces that are no longer supported by Remote Desktop Manager are flagged as ***(Deprecated)***, but are still available for use while being phased out. It is recommended to migrate them to a Devolutions Cloud workspace to avoid data loss. Here are the steps to do so:
1. Connect to the deprecated workspace you wish to migrate.
2. Tap the vertical ellipsis button (⋮) located in the top right corner and select ***Export all (.rdm)***.
3. Check the options of your choice (***Include credentials*** is highly recommended), and enter a ***Master key*** before tapping ***OK***.
4. [Create a Devolutions Cloud workspace](https://docs.devolutions.net/cloud/getting-started/create-your-devolutions-cloud-workspace/) or connect to an existing one.
5. Again, tap the vertical ellipsis button (⋮) located in the top right corner, but select ***Import into vault*** ***(.rdm, .json)*** this time.
6. Tap ***Import into root***, select the previously exported file, and enter the ***Master key***.
1. Go to the Remote Desktop Manager Android settings.
2. Select ***Workspaces***.
3. Enable ***Show deprecated workspace types***.
   {% endtab %}
{% tab title="iOS" %}
1. Tap the three bars in the top-left corner.
2. Navigate to the ***Settings***.
3. Select ***Workspaces.***
4. Enable ***Show deprecated workspace types***.
   {% endtab %}
   {% endtabs %}
GET https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/deprecated-workspaces.md?ask=<question>&goal=<endgoal>
