Skip to content
Deprecated workspaces
A deprecated workspace refers to a workspace that is no longer recommended or officially supported, primarily for security reasons.
Show deprecated workspaces
Follow this quick step-by-step guide to show deprecated workspace types.
  1. Click on File – Settings – Types – Sessions.
  2. Check Show deprecated workspace types.
  3. Click Save.
List of deprecated workspaces
Here is the current list of deprecated workspaces:
  • Microsoft Azure SQL
  • Microsoft SQL Server
  1. Add a new workspace.
  2. Click Show deprecated workspace types in the bottom-left corner of the window.
Migrating to Devolutions Cloud
Workspaces that are no longer supported by Remote Desktop Manager are flagged as (Deprecated), but are still available for use while being phased out. It is recommended to migrate them to a Devolutions Cloud workspace to avoid data loss. Here are the steps to do so:
  1. Connect to the deprecated workspace you wish to migrate.
  2. Tap the vertical ellipsis button (⋮) located in the top right corner and select Export all (.rdm).
  3. Check the options of your choice (Include credentials is highly recommended), and enter a Master key before tapping OK.
  4. Create a Devolutions Cloud workspace or connect to an existing one.
  5. Again, tap the vertical ellipsis button (⋮) located in the top right corner, but select Import into vault (.rdm, .json) this time.
  6. Tap Import into root, select the previously exported file, and enter the Master key.
  1. Go to the Remote Desktop Manager Android settings.
  2. Select Workspaces.
  3. Enable Show deprecated workspace types.
  1. Tap the three bars in the top-left corner.
  2. Navigate to the Settings.
  3. Select Workspaces.
  4. Enable Show deprecated workspace types.
Last updated
Was this helpful?
