Deploy Remote Desktop Manager using Microsoft Intune
This guide explains how to deploy Remote Desktop Manager to Windows devices using Microsoft Intune, and how to distribute a default configuration file so that all users start with a consistent Remote Desktop Manager setup.
Prerequisites
Remote Desktop Manager requires the Microsoft .NET 10 Windows Desktop Runtime (see System requirements). Intune installs Win32 apps silently and without user interaction, so deploy the runtime as its own Win32 app and set it as a dependency of the Remote Desktop Manager app. Intune then installs the runtime first on any device that does not have it.
  1. Download the .NET 10 Windows Desktop Runtime installer for x64 (windowsdesktop-runtime-10.x.x-win-x64.exe) from the official .NET download page.
  2. Package the installer as an .intunewin file with the Microsoft Win32 Content Prep Tool.
  3. In the Microsoft Intune admin center, go to Apps – All apps – Create, select Windows app (Win32), then upload the .intunewin file.
  4. On the Program page, enter the following commands, replacing 10.x.x with the version you downloaded:
    • Install command: windowsdesktop-runtime-10.x.x-win-x64.exe /install /quiet /norestart
    • Uninstall command: windowsdesktop-runtime-10.x.x-win-x64.exe /uninstall /quiet /norestart
    Set Install behavior to System.
  5. On the Detection rules page, select Manually configure detection rules, then add a File rule:
    • Path: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App
    • File or folder: 10.x.x (the version you packaged)
    • Detection method: File or folder exists
    To detect any .NET 10 Windows Desktop Runtime version instead of a specific one, use a custom detection script that checks for a 10.* folder under that path.
  6. Finish creating the app. You do not need to assign it to a group, because Intune installs dependencies automatically.
  7. Open the Remote Desktop Manager Win32 app, go to Properties – Dependencies, then click Edit. Click Add, select the .NET 10 Windows Desktop Runtime app, and set Automatically install to Yes. Save your changes.
When a new .NET 10 servicing release is published, package the new installer and update the commands and detection rule of the runtime app. For more information on dependencies, see Add and assign Win32 apps to Microsoft Intune – Dependencies.
Distribute the default configuration file
To prepare the configuration file, open Remote Desktop Manager and select your workspace. Then, navigate to File – Settings – Export settings. Select the settings you want to include and click Export.
Within Intune, deploy the RemoteDesktopManager.cfg file to C:\Users\%USERNAME%\AppData\Local\Devolutions\RemoteDesktopManager\.
See also
Last updated
Was this helpful?
