Delinea Secret Server entry settings
This article lists all the settings of the Delinea Secret Server credential entry in Remote Desktop Manager Windows. The SSO mode is supported in both cloud and self-hosted instances. If SSO is selected but not available, Remote Desktop Manager will automatically fall back to OAuth authentication, requiring users to manually enter their username and password.
General
URL
Enter the URL to connect to the Delinea Secret Server instance, which is either https://server or https://server/SecretServer.
Resolving mode
Choose whether to inject credentials directly into the session or to connect through a proxy.
Authentication mode
Choose an authentication mode between:
OAuth
SSO
Use "My account settings"
Retrieves the credentials stored under File – My account settings – Delinea Secret Server.
Use Windows authentication
Uses Windows authentication as credentials for the Delinea Secret Serverentry. Note that there is a limitation with the REST API: you cannot have an MFA with Windows authentication activated.
Username
Enter your Delinea Secret Server account username.
Password
Enter your Delinea Secret Server account password.
Always ask password
Choose whether to be asked for your password every time or not.
Multifactor mode
Select a multifactor mode between:
Ask at every login: an MFA prompt appears every time you use the credentials.
Ask only when session expires: the MFA prompt appears when Remote Desktop Manager is launched.
Credential selection
Look up
Determines what to look up to find credentials in Delinea Secret Server. If you would rather be shown all the credentials, choose Prompt with list instead.
Folder ID
Enter the ID of the folder in Delinea Secret Server. Leave blank to search through the whole list.
Mode
Choose a credential selection mode between:
As Credential
As private key
Advanced
Allow OTP retrieval
Determines whether the entry tries to fetch the OTP informations in Delinea Secret Server.
Trim machine/domain value after the first dot
Trim the value after the first dot in the machine/domain value, e.g., mydomain.lab.loc becomes mydomain.
Username field
Retrieves the value located the equivalent of the username field in Delinea Secret Server. Useful when field names do not match in custom entries.
Domain field
Retrieves the value located the equivalent of the domain field in Delinea Secret Server.
Password field
Retrieves the value located the equivalent of the password field in Delinea Secret Server.
See also
Last updated
Was this helpful?
