> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/data-report.md).
# Data report
Configure a Data Report entry in Remote Desktop Manager to let users run SQL queries and generate reports without direct server access.
The ***Data Report*** session type can be used to empower any/all users to generate reports, without having to grant them access to the actual server.
## Settings
### General
Create a Data Report entry and define the connection string by either:
* Specify the connection in the entry itself.
* Use a credential entry.
* Inherited from a parent.
* Prompt for credentials.
### Parameters
Specify the parameters by setting the name, type and default value of all parameters.
### Query
Enter the query in the Query tab, which features an SQL syntax-highlighted text box with line numbers.
Ensure that your DBA sets the proper user groups, and that each specific user(s) has access to it.
GET https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/data-report.md?ask=<question>&goal=<user_goal>
