> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/cyberark-system-safe-filtering.md).
# CyberArk system safe filtering
CyberArk safes do not have flags to indicate if they are for system or for general use. That being said, we can find in various CyberArk information sources that certain safes are indeed for the internal working of the vault exclusively. The following safes will be considered “system” safes, and by checking the appropriate option (typically labeled ***Hide system safes***), they will be hidden from lists.
{% hint style="success" %}
Go to ***File*** – ***Settings*** – ***Entry types*** – ***Credentials*** – ***CyberArk*** to add or delete ***Excluded safes***.
![](https://cdnweb.devolutions.net/docs/RDMW6087_2025_3.png)
* System
* VaultInternal
* Notification Engine
* PVWAConfig
* PVWAPrivateUserPrefs
* PVWAPublicData
* PVWAReports
* PVWATaskDefinitions
* PVWATicketingSystem
* PVWAUserPrefs
* PasswordManager
* PasswordManager\_ADInternal
* PasswordManager\_info
* PasswordManager\_workspace
* PasswordManagerShared
* PasswordManager\_Pending
GET https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/cyberark-system-safe-filtering.md?ask=<question>&goal=<endgoal>
