CyberArk system safe filtering
CyberArk safes do not have flags to indicate if they are for system or for general use. That being said, we can find in various CyberArk information sources that certain safes are indeed for the internal working of the vault exclusively. The following safes will be considered “system” safes, and by checking the appropriate option (typically labeled Hide system safes), they will be hidden from lists.
System
VaultInternal
Notification Engine
PVWAConfig
PVWAPrivateUserPrefs
PVWAPublicData
PVWAReports
PVWATaskDefinitions
PVWATicketingSystem
PVWAUserPrefs
PasswordManager
PasswordManager_ADInternal
PasswordManager_info
PasswordManager_workspace
PasswordManagerShared
PasswordManager_Pending
Last updated
Was this helpful?
