> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/access-and-manage-variables.md).
# Access and manage variables
Access and manage variables in Remote Desktop Manager entries and folders through the Properties panel to centralize dynamic field values.
Remote Desktop Manager has lists of all available [variables](https://docs.devolutions.net/rdm/concepts/intermediate-concepts/variables.md). Variables are versatile values that can be changed depending on the context. They act as containers for data, facilitating centralized control and manipulation.
To access and manage variables, right-click on any entry/folder, select **Properties**, and click on the **Variables** button.
### Availability
The availability of variables varies from one entry/folder to another, as it depends on what fields can be filled in the entry or folder. If [custom variables](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/manage-custom-variables.md) have been created for an entry, they will appear in the ***Custom Variables*** subsection located under ***General*** in the ***Entry Variables*** window of the entry ***Properties***.
The `$PARENT_NAME$` variable also resolves with the parent folder name of a “standard” entry that is not a sub-entry as long as they are not directly in root.
### Variable uses
As a general rule, variables can be used in any field of the entry/folder, though only variables with an ***X*** in the ***Supported in name*** column can be used in the ***Name*** field.
Variable types under the ***Folder*** section work with the first folder above the entry that is of that type. For example, setting a `$SITE_DOMAIN$` variable on an entry will return the domain found in the configured credentials of the first folder of the "site" type above that entry.
Some IP variables can cause performance issues or fail to return IP addresses in certain situations. It is recommended to [use this workaround](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/ip-variables.md) instead.
#### See also
* [Devolutions Academy - Utilizing Variables](https://academy.devolutions.net/student/path/1925316/activity/2668006)
* [Devolutions Academy – Managing Template group in Remote Desktop Manager](https://academy.devolutions.net/student/page/2591777-managing-template-group-in-remote-desktop-manager?sid=eafdf417-3c0e-4cf3-9add-30ad83c24c2c\&sid_i=0)
GET https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/access-and-manage-variables.md?ask=<question>&goal=<user_goal>
