VPN with offline mode
It is possible, when using a workspace that supports offline mode, to configure Remote Desktop Manager to activate the offline mode automatically upon launching a VPN connection from Remote Desktop Manager and to bring it back online at the VPN disconnection.
Solution
In the Properties – Settings of your VPN entry. You will need to enable two options:
Go Offline on connection.
Go Online on disconnect.
Last updated
Was this helpful?
