> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/user-specific-settings-encryption-migration.md).
# User-specific settings encryption migration
Understand how Remote Desktop Manager 2022.2 migrates User-specific settings to a newer encryption format and the available options.
The ***User-specific settings*** in Remote Desktop Manager 2022.2 are being migrated to a newer encryption format.
### Scenarios
1. Users who connect for the first time with this new version will receive this warning prompt:
*"User specific settings were migrated to a newer format. Do you want to delete the old ones? Doing so will make them unusable with Remote Desktop Manager prior to 2022.2."*
Options:
* ***Yes***: Will delete the existing ***User-specific settings*** and save a new encrypted version. This will prevent the user to utilize the ***User-specific settings*** with an older version of Remote Desktop Manager
* ***No***: This option will save a new encrypted version of the ***User-specific settings***, but will not delete the existing one. This will allow the user to keep on utilizing the previous ***User-specific settings*** on an older version or on the Remote Desktop Manager mobile version who are not yet updated.
2. While connecting, Remote Desktop Manager detects ***User-specific settings*** that are encrypted from an older Remote Desktop Manager version:
*"Some User Specific Settings were found in the old format used by Remote Desktop Manager prior to 2022.2."*
Options:
* ***Merge and Delete***: Will overwrite the encrypted ***User-specific settings*** with the data from the older Remote Desktop Manager and delete it.
* ***Merge***: Will overwrite the encrypted ***User-specific settings*** with the data from the older Remote Desktop Manager
* ***Delete***: The encrypted ***User-specific settings*** data will be kept and the previous one will be deleted.
* ***Cancel***: Nothing is changed.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/user-specific-settings-encryption-migration.md?ask=<question>&goal=<user_goal>
