Use multiple Edge website entries with different credentials in Remote Desktop Manager
It is possible to use multiple Edge website entries that each use different credentials. By using Profile names, it makes it possible to have a certain profile any number of times, making each unique or repeating it as many time as needed.
  1. Go into the Properties of a Website entry.
  2. Make certain the Display option is set to Embedded (tabbed) , or these steps may not work.
  3. Set the Web browser option to Microsoft Edge, in the Common – General – General tab.
  4. Input the desired website URL.
  5. Go to the Advanced tab.
  6. Check the Profile name option and input a name.
    Note that Remote Desktop Manager profiles are specific to Remote Desktop Manager and not related to Edge browser profiles.
  7. Click OK to save the changes and close the window.
Last updated
Was this helpful?
