Use legacy SFTP
You can revert to the legacy SFTP by enabling the UseLegacySFTPExplore option in the hidden settings of Remote Desktop Manager Windows.
  1. Go to File – Settings and press Ctrl + Alt + NOUI.
  2. The Hidden settings window will open.
  3. Locate UseLegacySFTPExplorer.
  4. Set the value to True.
  5. Click Save to close the window.
Last updated
Was this helpful?
