> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/use-different-versions-of-the-same-application.md).
# Use different versions of the same application
You have 2 different version of an application installed on your workstation and you want to be able to use both versions inside Remote Desktop Manager
When you configure your application installation path in ***File – Settings – Path***, separate the paths by a " ; ".
Remote Desktop Manager will prompt you with the selection list and you will be able to pick the one that you want to use.
Example: **C:\Program Files\Appsv1 ; D:\Program Files\Appsv2**
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/use-different-versions-of-the-same-application.md?ask=<question>&goal=<endgoal>
