Skip to content
SSH configuration for Remote Desktop Manager FIPS 140-2 compliance
For the Remote Desktop Manager SSH client to be compliant with the FIPS 140-2 annex A standard, you need to apply specific configuration changes in Remote Desktop Manager options.
These values originate from the Microsoft’s documentation FIPS140.2 annex A standard
  1. In Remote Desktop Manager, go to File – Settings – Types – Terminal – Algorithm support.
  2. In the Cipher tab, disable:
    • Chacha20 Poly1305 (openssh.com)
    • Aes256 Gcm (openssh.com)
    • Aes128 Gmc (openssh.com)
    • Rijndael Cbc (lysator.liu.se)
  3. In the Host key tab, disable:
    • Ssh Ed25519
    • X509v3 Sign Rsa
    • X509v3 Sign Rsa Sha256 (ssh.com)
    • Ssh Dss
  4. In the Kex tab, disable:
    • Curve25519 Sha256
    • Curve25519 Sha256 (libssh.org)
    • Diffie Hellman Group16 Sha512
    • Diffie Hellman Group18 Sha512
    • Diffie Hellman Group14 Sha256
    • Diffie Hellman Group1 Sha1
  5. In the MAC tab, disable:
    • Hmac Sha 1 96
    • Hmac Md5 96
    • Hmac Md5
  6. Click OK.
Last updated
Was this helpful?
