> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/set-up-user-vault-credentials-in-remote-desktop-manager.md).
# Set up user vault credentials in Remote Desktop Manager
Apply user vault credentials to an entry in Remote Desktop Manager using a user-specific setting without affecting other users.
You can configure an entry to apply credentials that are in your user vault without affecting other users' settings. To do so, you need to create a ***User-specific setting***. Follow the steps below.
1. Select the entry in the ***navigation pane***, then go to ***Edit – User-specific settings***.
2. In the ***General*** tab, enable ***Override credentials***.
3. In the drop-down list next to this option, select ***Linked***, then select your user vault in the vault list.
4. Select your credentials or, alternatively, select ***Prompt on connection*** to receive a list of credential entries when you connect to the session entry.
5. Click ***OK*** to save your changes.
You will now be prompted for the credentials you selected to open the entry.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/set-up-user-vault-credentials-in-remote-desktop-manager.md?ask=<question>&goal=<user_goal>
