> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/set-up-an-ai-assistant.md).
# Set up an AI assistant
Remote Desktop Manager supports AI integration with Azure OpenAI, OpenAI, Ollama, Gemini, Mistral AI, Claude (Anthropic) and Azure AI Inference. These can be leveraged through an ***AI assistant*** session entry or the ***AI assistant*** panel.
Data is only processed through these customer provided AI integrations.
To link your preferred AI provider with Remote Desktop Manager via a session entry, follow the steps below:
1. Click on ***New entry***, then find the ***AI assistant*** session entry under ***Session*** – ***Remote connections***. Click on ***Save***.
   ![](https://cdnweb.devolutions.net/docs/RDMW4251_2025_1.png)
2. Enter a ***Name*** for the new entry, choose a ***Provider***, select a ***Model***, and input an ***API key*** (and an ***Endpoint*** if applicable). Click on ***Save***.
   ![](https://cdnweb.devolutions.net/docs/RDMW4252_2025_1.png)
To use the AI assistant as a separate side panel, head over to ***File*** – ***Settings*** – ***AI***, enter your provider’s informations, and click on ***Save***. Then, click on the ***AI assistant*** button in the ***Window*** menu bar, located in the ***Panels*** section.
![](https://cdnweb.devolutions.net/docs/RDMW4254_2025_1.png)
### Connect an AI assistant to local MCP server
1. First, configure a [local MCP server](https://docs.devolutions.net/rdm/commands/tools/more-tools/mcp-server/).
2. Click the ***Add*** button in the ***MCP servers*** section (either in ***File*** – ***Settings*** – ***AI*** or an ***AI assistant*** entry).
   ![](https://cdnweb.devolutions.net/docs/RDMW4432_2026_1.png)
3. Minimally enter a ***Name***, ***Type*** and ***Web URL*** or your MCP server, then click ***Ok***. Cick ***Save*** to effectuate the changes.
### See also
* [Spotlight on: Remote Desktop Manager AI assistant](https://blog.devolutions.net/2025/03/spotlight-on-remote-desktop-manager-ai-assistant/)
* [Devolutions Academy – Create and use AI assistant in RDM](https://academy.devolutions.net/student/activity/2639962-create-and-use-ai-assistant-in-rdm)
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/set-up-an-ai-assistant.md?ask=<question>&goal=<endgoal>
