> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/set-a-default-documentation-template-for-a-vault.md).
# Set a default documentation template for a vault
Learn how to set a default documentation template for all entries in a vault.
2. In the navigation pane, right-click the vault name at the top of the tree, then select ***Properties***.
3. In the left menu, click ***Documentation***.
4. Select ***Manage templates*** and create a template with the content you want. Save and close.
   ![](https://cdnweb.devolutions.net/docs/RDMW6088_2025_3.png)
5. Back in ***Documentation***, set ***Default template*** to ***Custom***.
6. In ***Template*** (on the right), choose the template you created.
7. Enter the ***Documentation title*** (e.g., Windjammer documentation) and select a ***Documentation type***.
8. Select ***Save***.
9. Select an entry.
10. Go to the **Documentation** tab to view the template you previously created.
    ![](https://cdnweb.devolutions.net/docs/RDMW6089_2025_3.png)
### See also
* [Devolutions Academy – Predefine a documentation template for all new entries in RDM](https://academy.devolutions.net/student/activity/3123671-predefine-a-documentation-template-for-all-new-entries-in-rdm)
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/set-a-default-documentation-template-for-a-vault.md?ask=<question>&goal=<endgoal>
