Set a default documentation template for a vault
Learn how to set a default documentation template for all entries in a vault.
Open Remote Desktop Manager.
In the navigation pane, right-click the vault name at the top of the tree, then select Properties.
In the left menu, click Documentation.
Select Manage templates and create a template with the content you want. Save and close.
Back in Documentation, set Default template to Custom.
In Template (on the right), choose the template you created.
Enter the Documentation title (e.g., Windjammer documentation) and select a Documentation type.
Select Save.
Select an entry.
Go to the Documentation tab to view the template you previously created.
See also
Last updated
Was this helpful?
