> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/session-recording.md).
# Session recording
Enable session recording in Remote Desktop Manager to capture video logs of remote connections at the vault, folder, or entry level.
A session recording provides a record of what a user did while a remote connection was opened in Remote Desktop Manager. By default, it records one frame per second and creates a video in `.webm` format. SSH Shell and Telnet sessions are recorded in the format set in ***SSH recording mode***: ***Terminal playback (.trp)*** by default, ***Asciicast (.cast)*** or ***Video (.webm)***. The frame rate and the SSH recording mode are set in the ***Recording*** section of the application settings (***File*** – ***Settings*** – ***Application*** – ***Recording*** on Windows and Linux), unless the workspace settings define them.
You can configure session recording at the vault, folder or entry level and they can be optional or required.
{% hint style="warning" %}
Session recording is only available in embedded mode. A session that requires recording cannot be opened externally.
### Supported sessions
* Active Directory dashboard
* Apple Remote Desktop
* Azure Blob Storage
* Dell iDRAC
* FTP (Windows and Linux)
* HP iLO
* Raw (Terminal)
* RDP
* RDP over Delinea Secret Server Proxy
* S3
* SCP (Windows and Linux)
* SFTP (Windows and Linux)
* SSH over Delinea Secret Server Proxy
* SSH Shell
* Telnet
* TN3270
* TN5250
* VNC, except with the UltraVNC library
* WebDAV
* Website, except with the Internet Explorer engine
### Configure session recording
1. Open ***Administration*** – ***Vault settings***, or the ***Properties*** of a folder or an entry.
2. Select ***Security*** – ***Session recording***. If the section is not shown, select ***Show all properties***.
3. Choose a ***Mode***.
| MODE                          | DESCRIPTION        |
| **Default (Inherited)**       | Uses the value of the parent folder, up to the vault. At the vault level, ***Default (Never)***.                                    |
| **Optional**                  | User is prompted to record when they open the session. If they decline, the session still opens.                                    |
| **Required**                  | Recording starts automatically. If the recording cannot start, the session does not open.                                           |
| **Required (when supported)** | Recording starts automatically on the platforms that support session recording. On the others, the session opens without recording. |
| **Never**                     | Session recording is turned off.        |
| **Root**                      | Uses the value of the vault. Not offered at the vault level.        |
4. With a Devolutions Server or Devolutions Cloud workspace, choose the ***Recording*** method: ***Local*** to save the recording with Remote Desktop Manager, or ***Remote*** to send it to the recording server of the workspace or to Devolutions Gateway.
5. With ***Remote***, choose the ***Gateway mode***. With ***Custom***, select the Devolutions Gateway that records the session in ***Gateway***. It can be a different gateway from the one used for the connection.
6. For a local recording, choose the ***Destination***: ***Default*** uses the value of the parent folder, up to the default recording folder of Remote Desktop Manager; ***Custom*** uses the folder entered in the field that appears.
7. Choose the ***Filename***: ***Connection log ID***, ***Entry name***, ***Entry Name + Date/Time*** or ***Custom***. At the vault level, the default is ***Entry Name + Date/Time***.
8. With ***Custom***, enter the filename, which can contain [variables](https://docs.devolutions.net/rdm/concepts/intermediate-concepts/variables.md), or select ***Prompt for name*** to ask the user for the filename when the recording starts.
9. Save the changes.
Every setting of the section is described in [Session recording settings](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/entry-settings/common-settings/session-recording.md).
### Notify users that their session is recorded
An administrator can show a confirmation message to users before an entry with session recording opens. The user then chooses whether to open the entry.
1. Go to ***Administration*** – ***System settings*** – ***Application*** – ***Session recording***.
2. Check ***Prompt confirmation message before opening an entry with session recording***.
3. To replace the default message, enter your own text in ***Custom message***. When the field is empty, users see "This session will be recorded. Do you want to continue?"
4. Save the changes.
The message is shown when the session recording ***Mode*** of the entry is ***Required*** or ***Required (when supported)***. If the user declines, the entry does not open. No message is shown with ***Optional***, because the user already chooses to record the session when it opens.
With a Devolutions Server workspace, the same setting is also available in the web interface, under [System settings – Recording server](https://docs.devolutions.net/server/web-interface/administration/configuration/system-settings#recording-server). Sessions opened from the Devolutions Server web interface show the same message.
### Session recording all-in-one interface
The dashboard of the vault has a ***Recordings*** tab that provides an all-in-one interface for viewing and downloading all recordings for supported sessions.
Recordings can also be accessed by right-clicking on the entry and selecting ***View*** – ***Recordings***.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/session-recording.md?ask=<question>&goal=<user_goal>
