Reinstall Remote Desktop Manager
Refer to Installation Overview for details on the installation of Remote Desktop Manager.
Settings
After Remote Desktop Manager has been reinstalled on your computer, you need to copy your RemoteDesktopManager.cfg, RemoteDesktopManager.enc, and RemoteDesktopManager.stv (that you had backed up) to the %LocalAppData%\Devolutions\RemoteDesktopManager folder This is the default path. I f you have not installed with the default settings, please consult Configuration File Location for instructions on locating your configuration folder.
Data
If you have moved the file based workspace to another relative path, you will have to edit the workspace definitions to fix the paths.
PreviousRecord an SSH session as a TRP file
NextRemote Desktop Manager typing macro to perform authentication
Last updated
Was this helpful?
