Proxmox dashboard entry
The Proxmox entry in Remote Desktop Manager Windows provides a centralized way to manage and launch Proxmox sessions directly from within your vault.
Basic operations such as listing virtual machines and performing actions like Start, Stop, Reboot, Pause, and Resume (VMs only) are available from the context menu. Containers (LXC) support Start, Stop, Reboot, and Shutdown; Virtual Machines (QEMU) also offer these options plus Pause and Resume.
Token-based authentication
The Token-based authentication uses an API key without expiration.
Open Remote Desktop Manager.
Add a new entry.
Go to Session and select Proxmox dashboard.
Enter the URL of the Proxmox server.
Select Token as Authentication mode.
Type the Username under which this token will authenticate.
Select the Realm, which is the authentication backend.
Enter the unique identifier for the Token id.
Type the token secret value used for API authentication.
Click Add to save and close the window.
Ticket-based authentication
Ticket-based authentication uses a username and password to establish a session that remains valid for two hours, with an automatic refresh occurring two minutes before expiration.
Add a new entry.
Select Ticket as Authentication mode.
Type the Proxmox account under which this token will authenticate.
Enter the password.
Click Add to save the entry.
Last updated
Was this helpful?
