> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/performance-diagnostic.md). Agents can also search and read this documentation through its [MCP server](https://docs.devolutions.net/~gitbook/mcp).
# Performance diagnostic
Run a performance diagnostic in Remote Desktop Manager by sending workspace traces or a SQL disk usage report to Devolutions support.
When a performance issue occurs while using Remote Desktop Manager Windows, the support team may ask you to send a few details regarding your workspace, system settings, etc. Follow one of the two methods below to gather the information and send it the support team.
### Send performance trace via Remote Desktop Manager
1. Open ***File*** – ***My workspace information***.
2. Click on the ***Email report to support*** button to send the information to the support team.
3. Open ***Help*** – ***System diagnostic***.
4. Click on the ***Send*** button.
5. Include enough information to link the report to the appropriate ticket. Remember to enter your username if the process was started from the forum.
6. Next, go to ***Help*** – ***Performance profiling.***
7. In Remote Desktop Manager, hold the <kbd>Ctrl</kbd> key and press the refresh button.
8. Information will be added in the ***Performance*** tab of the performance profiling window opened during step #6.
9. Click on the ***Send trace to support*** button. Again, ensure that you include enough information to link the report to the appropriate ticket, and enter your forum username if the process was started from the forum.
### Email a Disk usage by Top Tables report via SSMS
For Devolutions Server, SQL, and SQL Azure workspaces, a ***Disk usage by Top Tables*** ***report*** from ***SQL Server Management Studio (SSMS)*** can be generated in order to assess the number of records in specific database tables. Here's how to do so:
1. Open ***SQL Server Management Studio (SSMS)***.
2. Right-click the database and select ***Reports*** – ***Standard Reports*** – ***Disk Usage by Top Tables***.
3. Send the report to <service@devolutions.net>.
Here is the ***SQL query*** to get the same result if the database is hosted on Azure.
SELECT TOP 1000
        a3.name AS SchemaName,
        a2.name AS TableName,
        a1.rows as Row_Count,
        (a1.reserved )* 8.0 / 1024 AS reserved_mb,
        a1.data * 8.0 / 1024 AS data_mb,
        (CASE WHEN (a1.used ) > a1.data THEN (a1.used ) - a1.data ELSE 0 END) * 8.0 / 1024 AS index_size_mb,
        (CASE WHEN (a1.reserved ) > a1.used THEN (a1.reserved ) - a1.used ELSE 0 END) * 8.0 / 1024 AS unused_mb
    FROM    (   SELECT
                ps.object_id,
                SUM ( CASE WHEN (ps.index_id < 2) THEN row_count    ELSE 0 END ) AS [rows],
                SUM (ps.reserved_page_count) AS reserved,
                SUM (CASE   WHEN (ps.index_id < 2) THEN (ps.in_row_data_page_count + ps.lob_used_page_count + ps.row_overflow_used_page_count)
                            ELSE (ps.lob_used_page_count + ps.row_overflow_used_page_count) END
                    ) AS data,
                SUM (ps.used_page_count) AS used
                FROM sys.dm_db_partition_stats ps
                GROUP BY ps.object_id
            ) AS a1
    INNER JOIN sys.all_objects a2  ON ( a1.object_id = a2.object_id )
    INNER JOIN sys.schemas a3 ON (a2.schema_id = a3.schema_id)
    WHERE a2.type <> N'S' and a2.type <> N'IT'
    order by a1.reserved desc
```<div data-gb-custom-block data-tag="hint" data-style='info'>For Devolutions Server workspaces, the [Cleanup logs](https://docs.devolutions.net/server/web-interface/administration/database-retention-policies/) feature (***Administration*** – ***Logs*** – ***Clean up logs, i***n the Devolutions Server web interface) can help reduce the number of records in the report table by automatically archiving/deleting old logs.</div>
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/performance-diagnostic.md?ask=<question>&goal=<user_goal>
