> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/passcode-prompt-when-opening-an-entry.md).
# Passcode prompt when opening an entry
Set a passcode prompt as a safeguard before opening a Remote Desktop Manager entry, confirming with a custom message and required passcode.
Sometimes you want to ensure that your users are really opening the right session.
In the ***Events*** tab, in the ***Before connect*** section, when you select ***Message Prompt***, you will notice a ***Passcode*** field.
There is a field to enter a ***Message*** and another one for a ***Passcode*** The idea is not to add another password to launch the session, but rather to act as a safeguard. For example, you could set the message to “Warning! This is a production server. Type YES to continue.” and set the ***Passcode*** to YES.
This allows you to give just a little jolt when you attempt to launch the session.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/passcode-prompt-when-opening-an-entry.md?ask=<question>&goal=<user_goal>
