Keyboard shortcuts customization
Remote Desktop Manager assigns a key combination to many of its commands. You can change the key combination of each shortcut, disable a shortcut, or return it to its default value. These options are found in File – Settings – User interface – Keyboard. On macOS, you can also open the settings from Remote Desktop Manager – Settings in the menu bar at the top of the screen.
For a list of default values for shortcuts, visit Keyboard shortcuts.
Modify shortcuts
The controls used to change a shortcut differ on macOS.
  1. Under the Keyboard section, find the shortcut to modify in the list. Shortcuts are grouped by category.
  2. In the Mode column, select Default, When not in session, Global hotkey, or None.
  3. In the Shortcut column, select the key combination.
  4. Click Save.
  5. On Windows, restart Remote Desktop Manager to apply the changes. On Linux, the changes apply when the settings are saved.
If the selected key combination is already used by another shortcut or by a shortcut macro, Remote Desktop Manager asks whether to override it. Click Yes to assign the key combination and remove it from the other shortcut, or No to keep the previous key combination.
The Reset to default button returns the mode and key combination of every shortcut in the list to its default value. The Disable all button sets the Mode and Shortcut of every shortcut to None. Both buttons apply when the settings are saved, and do not affect shortcut macros.
  1. In the Shortcuts section, select the shortcut to modify in the list. To find it, type its name in the Search box.
  2. In the Mode list, select Custom to specify a new key combination, None to disable the shortcut, or Default to use its default key combination.
  3. For a Custom shortcut, press a key in the Key box.
  4. For a Custom shortcut, select or clear the Ctrl, Alt, Shift, and Cmd checkboxes.
  5. Repeat these actions for each shortcut to modify.
  6. Click Save.
The changes apply when they are saved, without restarting Remote Desktop Manager. Changes that are not saved yet are also saved when the settings window is closed.
The Reset button cancels the changes that are not saved yet. The Restore defaults button sets every shortcut back to Default; click Save to keep this change.
Global hotkeys
On Windows, a shortcut in Global hotkey mode is registered with Windows when Remote Desktop Manager starts. It works even when another application has the focus, and its key combination is unavailable to other applications while Remote Desktop Manager is running. Changes to a global hotkey take effect only after Remote Desktop Manager restarts.
On Linux, a shortcut in Global hotkey mode is not registered with the system and works only while Remote Desktop Manager has the focus. This mode is not available on macOS.
Clipboard - Next value
The Clipboard - Next value shortcut, in the Actions category, is available on Windows only. It is a global hotkey with the default key combination Ctrl+Alt+V. It is used with the Copy username and password action: when the target application does not move the clipboard to the password after the username is pasted, press the shortcut to put the next value in the clipboard. This applies to Chromium-based browsers and to Electron applications such as Slack or Microsoft Teams. While the clipboard waits for this shortcut, the status bar displays the key combination to press.
Because the shortcut is global, Ctrl+Alt+V is unavailable to other applications while Remote Desktop Manager is running, for example Paste Special in Microsoft Office. To free this key combination, assign another key combination to Clipboard - Next value or set its Mode to None, then restart Remote Desktop Manager.
Create shortcut macros
On Windows, you can create custom Macros and pair them with Shortcut key combinations. The Shortcut macros section is not available on macOS and Linux.
  1. Under the Shortcut macros section, click Add. A new macro line appears.
  2. In the Shortcut column, select the key combination.
  3. In the Macro column, select one of the available macros or write your own.
  4. In the Mode column, select Default, When not in session, Global hotkey, or None.
  5. In the Window column, select Execute in the previous window or Execute in current tab.
  6. Click Save.
  7. Restart Remote Desktop Manager to apply the changes.
To delete one or more shortcut macros, select the checkbox next to them, click Delete, then click Delete in the confirmation window.
Ignore key combinations in embedded sessions
On macOS, key combinations in the The following key combinations are ignored by embedded sessions list are not sent to embedded sessions, to avoid conflicts. Some key combinations are ignored by default. Changes to this list are saved immediately. This list is not available on Windows and Linux.
  • To ignore the key combination of a shortcut, drag the shortcut from the Shortcuts list to the ignored key combinations list.
  • To ignore another key combination, press a key in the box below the list, select the Ctrl, Alt, Shift, and Cmd checkboxes as needed, then click Add.
  • To remove key combinations from the list, select them, then click Delete.
  • To return the list to its default content, click Restore defaults next to Delete.
Other keyboard settings
On Windows, the Other section contains the following options. This section is not available on macOS and Linux.
  • Disable minimize on Escape key press
  • Disable open with Enter key
  • Filter the tree list only on Enter key press (available when Disable open with Enter key is selected)
See also
Last updated
Was this helpful?
