> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/keepass-plugin-installation-on-a-rds.md).
# KeePass plugin installation on a RDS
Install the KeePass plugin on a Remote Desktop Service alongside Remote Desktop Manager and configure the plugin installation path.
Using Remote Desktop Manager and KeePass on a Remote Desktop Service require multiple steps.
### Requirements
The installation of Remote Desktop Manager follows [Terminal Services / Remote Desktop Services](https://docs.devolutions.net/rdm/getting-started/installation/client/remote-desktop-services-terminal-services.md).
Make sure that the installation of KeePass was successful and is not on a network drive.
### KeePass plugin
1. [Download the KeePass plugin](https://keepass.info/download.html).
2. Unzip the files in the installation folder of KeePass (e.g., `C:\Program Files (x86)\KeePass Password Safe 2`).
3. KeePass installation path (`File – Settings – Clipboard – Paths – Configure installation path`), has to be configured in **default.cfg** refereed in [Terminal Services / Remote Desktop Services](https://docs.devolutions.net/rdm/getting-started/installation/client/remote-desktop-services-terminal-services.md).
4. To manually edit **default.cfg**, adjust the path and add the line in context: `C:\Program Files (x86)\KeePass Password Safe 2`.
Whenever Remote Desktop Manager is started and it detects a new default.cfg file, a dialog window will appear.
By selecting Use new configuration, the user's configuration is simply overwritten. If you only wish to update the Remote Desktop Manager license key after a renewal, choose ***Retrieve new registration only***.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/keepass-plugin-installation-on-a-rds.md?ask=<question>&goal=<user_goal>
