IT asset management in Remote Desktop Manager
Asset
The Asset section of a Remote Desktop Manager entry is used to manage and document detailed information about IT assets, such as a computer, server, or other hardware. The settings of this section are detailed in Asset.
  1. Right-click on an entry and select Properties.
  2. Click Show all properties if the Asset section is not displayed.
  3. Go to View – Asset.
  4. Enter the information.
  5. Click Save to save the changes and close the window.
  6. In the entry Dashboard, select the Asset tab to view the information.
IT asset management
The IT asset management section links an entry to its record in an asset management service (e.g., BlueTally, Lansweeper) through the entry properties. The settings of this section are detailed in IT asset management.
The IT asset management section is available for session entries, which include VPN and remote management entries. It is not available on macOS. The IT asset entries work differently from this section.
  2. Click Show all properties if the IT asset management section is not displayed.
  3. Go to View – IT asset management.
  4. Select a Service type in the dropdown list.
  5. Enter the URL of the asset in URL.
  6. Click Save to save the changes and close the window.
  7. In the entry Dashboard, select the IT asset management tab.
  8. Log in to the asset management service.
The dashboard tab is named after the Title field of the section. When the field is empty, the title set on the vault or in the workspace settings is used. Otherwise, the tab is named BlueTally or Lansweeper for these service types, and IT asset management for the others.
See also
Last updated
Was this helpful?
