> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/ip-address-list-entry.md).
# IP address list entry
{% tabs %}
{% tab title="Windows" %}
The ***IP Address list*** entry keeps the list of IPs in a single entry.
1. In Remote Desktop Manager Windows select ***Add new entry***.
2. Choose ***It asset management*** – ***IP address list***.
3. Click ***OK***.
   ![](https://cdnweb.devolutions.net/docs/docs_en_kb_KB6109.png)
4. Enter a ***Name*** and select a ***Folder***.
5. Click ***Add (+)***.
6. Enter the ***Name***, ***IP / Host*** and ***Description*** of the IP address.
7. Click ***OK*** to close the window.
8. You can also add auto-add IP addresses from relevant entries directly from your current vault.
   * ***Synchronize with vault***: Update existing entries by matching them with host matches from the vault. You can choose to remove entries that no longer exist and update specific fields such as ***Name***, ***Host***, or ***Description***.
   * ***Add to existing list***: Add new entries to your list without modifying or deleting any existing ones. This method allows duplicates and avoids overwriting existing data.
   * ***Advanced options***: Gives you control over how duplicates are managed and which fields are included.
     ![](https://cdnweb.devolutions.net/docs/RDMW6002_2025_2.png)
9. Click ***OK*** to save the entry.
10. The ***IP Adress list*** entry is saved.
    {% endtab %}
{% tab title="macOS" %}
1. In Remote Desktop Manager macOS, select ***Add new entry***.
3. Click ***OK***.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_rdm_mac_RDMMac6050.png" alt=""><figcaption></figcaption></figure>
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_rdm_mac_RDMMac6051.png" alt=""><figcaption></figcaption></figure>
5. Go to ***IP address list*** and click ***Add (+)***.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_rdm_mac_RDMMac6052.png" alt=""><figcaption></figcaption></figure>
6. Enter the ***Name***, ***IP / Host***, and ***Description*** of the IP address.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_rdm_mac_RDMMac6054.png" alt=""><figcaption></figcaption></figure>
8. Enter the number of IP addresses to list. You can also edit or delete an IP address.
9. Click ***Save*** to save the entry.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_rdm_mac_RDMMac6053.png" alt=""><figcaption></figcaption></figure>
{% endtab %}
{% endtabs %}
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/ip-address-list-entry.md?ask=<question>&goal=<endgoal>
