Install Remote Desktop Manager using Chocolatey
Installing Remote Desktop Manager can be streamlined using Chocolatey, a package manager for Windows. Begin by installing Chocolatey; if you already have Chocolatey installed, you can proceed directly to the Remote Desktop Manager installation steps.
Install Chocolatey
Prerequisites
To install Chocolatey, ensure your system meets the following requirements:
Operating system: Windows 7 or later / Windows Server 2003 or later
PowerShell: Version 2 or later
.NET Framework: Version 4 or later
Installation steps
Open PowerShell as an administrator. To do so, you can press Windows+X and select Terminal (Admin).
Copy and paste the following installation command into the PowerShell window and press Enter:
Set-ExecutionPolicy Bypass -Scope Process -Force; [System.Net.ServicePointManager]::SecurityProtocol = [System.Net.ServicePointManager]::SecurityProtocol -bor 3072; iex ((New-Object System.Net.WebClient).DownloadString('https://chocolatey.org/install.ps1'))After the command completes, verify the installation by running the
chococommand. If Chocolatey is installed correctly, you should see the Chocolatey version.
Install Remote Desktop Manager with Chocolatey
choco install rdm -y. The-yflag automatically approves all prompts, facilitating an unattended installation.
Once the installation completes, Remote Desktop Manager will be ready to use on your system.
Last updated
Was this helpful?
