Import credentials from KeePass
Remote Desktop Manager Windows imports credentials from KeePass. It is a simple way to build your data. The imported information can be converted into two types of entry: Credentials and Website. Entries include credentials, URL addresses and notes.
Export entries from KeePass
In the File menu, click Export.
Export data to an external file. Remote Desktop Manager supports two file types for KeePass:
.xmland.csv. An.xmlfile will retain the folder structure from KeePass.Choose desired file type: KeePass CSV (1.x) or KeePass XML (2.x).
Select path to save the exported file.
Import data into Remote Desktop Manager
The data is imported into the currently selected folder.
Choose the file type to import in File – Import.
Go to the Passwords and credentials tab.
Select the KeePass format to import. The available formats are
.csv,.xmland Link.Choose an entry type. All imported entries are converted to this type.
Credentials
Includes username, password and domain.
Website
Includes username, password, and website address. Good choice for website information and can be used with the Devolutions Password Manager browser extension.
Select the KeePass exported file in the file explorer.
Choose the entries you want to import.
The imported entries are ready to use.
Last updated
Was this helpful?
