> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/hide-the-legacy-security-removal-warning-box-in-remote-desktop-manager.md).
# Hide the legacy security removal warning box in Remote Desktop Manager
Edit the Remote Desktop Manager configuration file manually with a text editor to hide the legacy security removal warning box.
{% hint style="danger" %}
Legacy security has been deprecated and will be completely removed starting with version 2023.3 of Remote Desktop Manager. See [Disable legacy security in Remote Desktop Manager](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/disable-legacy-security-in-remote-desktop-manager.md).
The warning box cannot be permanently hidden from the interface, but a manual solution is available.
1. Close Remote Desktop Manager.
2. Go to your Windows search bar and type **%localappdata%**. Press Enter or click on it.
3. Go to **Devolutions\RemoteDesktopManager\RemoteDesktopManager.cfg**.
4. Edit **RemoteDesktopManager.cfg** by using your preferred text editor.
5. Add the following lines to the file:
   <HideLegacySecurityWarning>true</HideLegacySecurityWarning>
   <HideMySQLWarning>true</HideMySQLWarning>
6. Save your file.
7. Open Remote Desktop Manager.
The legacy security removal warning box should now be hidden.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/hide-the-legacy-security-removal-warning-box-in-remote-desktop-manager.md?ask=<question>&goal=<user_goal>
