Google Workspace console entry
The Google Workspace console entry enables direct management of Google Workspace resources (users, groups, and organizational units) from Remote Desktop Manager, streamlining the administration workflow and simplifying access management and sharing.
Configuration
Add a new entry in Remote Desktop Manager.
Go to Session and select Google Workspace.
Enter the name and select a folder.
Choose the type of credentials.
Authenticate the Account status by clicking Validate.
Google Workspace console entry settings
New
Create the selected user, group, or organizational unit
Delete
Delete the selected user, group, or organizational unit.
Properties
View and edit the properties of the selected user, group, or organizational unit. Double-clicking also opens the properties menu.
Reset password
Reset the password of the selected user’s account.
Suspend/Reactivate
Suspend or reactivate the selected user’s account without deleting it.
Groups
Manage the selected user’s group memberships by adding or removing them from groups.
Members
Add or remove users from the selected group.
Last updated
Was this helpful?
