Export and import favorites
Learn how to export and import the entries tag Favorites when migrating data.
Export
In the Remote Desktop Manager navigation pane, select your workspace.
Click the Favorites icon.
Click the ellipsis button.
Select Export.
Save the .xml file on your computer.
Import
In the navigation pane, select your new workspace.
Select Import.
Locate the .xml file on your computer and click Open.
Last updated
Was this helpful?
