Execute a PowerShell script before opening a connection
It is possible to execute a PowerShell script before establishing a connection, to cancel the launching, and even to import external PowerShell scripts. To accomplish these actions, you would need to go into the Properties of the entry under Events – Before opening, and choose Execute PowerShell in the topmost dropdown menu.
Using the $RDM.connection property, the script temporarily changes any of the session’s properties in the context of the session launch only. When the session is closed, the properties revert to their original values.
Below are some examples of scripts that can be executed in this manner.
Add date to tab title
In the PowerShell script window, copy the script provided below and click OK.
$date = Get-Date -DisplayHint Date
$RDM.Connection.TabTitle = $RDM.Connection.Name + "(" + $date + ")"Cancel session launch
To cancel the launch of a session, in the PowerShell script window of the entry, copy the script below and click OK to save.
$RDM.Cancel = $trueRun cmdlets from Devolutions PowerShell module
The Devolutions PowerShell module can be used to run cmdlets in specific entries using the Import-Module command.
Import-Module DnsClient
$RDM.connection.TeamViewer.ID = (Resolve-DnsName -Name $HOST$).IPAddressIn this example, the script loads the DnsClient using Import-Module, looks up the IP address for the hostname of the entry, and writes it into the TeamViewer ID field.
Import external PowerShell script
The Import-Module cmdlet can be used to call an external PowerShell script.
In this sample, the Import-Module cmdlet loads the RSAToken.ps1 script and calls its function New_RSAToken, which returns a value. Then it appends the content of the $RSAToken variable to the session’s password before opening the session.
Last updated
Was this helpful?
