Enterprise deployment of Remote Desktop Manager
The custom installer service, offered through our Devolutions Portal services, replicates the configuration from a Remote Desktop Manager instance. This configuration is used to create an installer file (*.rdi), which will be used to create the installation package intended for distribution.
Once you have created the installation package with our custom installer service, deploy it and copy the default.cfg in the installation folder, which by default is under %ProgramFiles(x86)%\Devolutions\RemoteDesktopManager.
PreviousEnable temporary access
NextEstablish a remote access to a Linux machine with Remote Desktop Manager
Last updated
Was this helpful?
