Enable smart cards authentication in Remote Desktop Manager macOS
Here are the steps to enable the Smart cards authentication in Remote Desktop Manager macOS:
In an RDP session, enable the Smart cards device under the Local ressources tab.
In the Connection tab, disable the Activate network level authentication NLA (SingleSignOn).
Click Save.
Last updated
Was this helpful?
