Enable MFA for users
While it is still not possible to force the configuration of multifactor authentication (MFA) at the user level without Devolutions Server, a few options have been added in Remote Desktop Manager that could suit your needs.
Force application multifactor authentication mode
In Administration – System Settings – Applications – Security – Force application multifactor authentication mode, select either:
Default (Don't force): Does not force application multifactor authentication mode.
Check against all configured methods: Prompts for the configured MFA methods only.
Prompt for selection on use: Prompts for which MFA to configure on use.
Force application security with TOTP (Authenticator)
In Administration – System Settings – Applications – Security, check Force application security with TOTP (Authenticator) to enable it.
Force application security with Duo (Authenticator)
In Administration – System Settings – Applications – Security, check Force application security with Duo (Authenticator) to enable it.
Force workspace multifactor configuration
In Administration – System Settings – Vault Management – Security Settings – Security, check Force workspace multifactor configuration to enable it.
Prompt for MFA before going offline
In Administration – System Settings – Application – Cache/Offline – Offline, check Prompt for MFA before going offline to enable it.
Force with group policies (GPOs)
We also have GPOs that could help you achieve your goal. An example is the Force multifactor authentication on the application login GPO.
%Root%\SOFTWARE\Policies\Devolutions\RemoteDesktopManager\ForceApplicationMFA
See also
Last updated
Was this helpful?
