Display RDP on multiple monitors
Remote Desktop Manager allows displaying multiple remote screens in an RDP session, provided there are as many local monitors as remote ones. For example, if a technician has a single local monitor, and the remote has two, they will only be able to see the primary screen of the remote session.
To view an application that does not show on the displayed monitor, use the key combination Windows+Shift+Left/Right. Alternatively, many applications let the user right-click the icon in the task bar and use the Move to the current display option.
  1. In the Properties of an RDP entry, set the local Display to External.
  2. In the remote Display section enable the option Span on multiple screens if possible.
Use multiple monitors for the remote session
The Windows screen display IDs are not necessarily the same as the RDP. The RDP monitors ID will also start with 0, not 1.
To discover the local RDP screen settings, use the command mstsc /l.
Enabling the Use multiple monitors for the remote session in the General – Display section unlocks the All or Selected settings.
If Selected is chosen, click on the ellipsis button (...) and pick the desired displays in the dropdown menu (put a space or comma between the monitors to identify them). The remote host will then be displayed on the monitor specified in the field.
Local monitor and desktop selection
In External display mode, choose on which local monitor the session is to be displayed.
The second drop down menu should always be left to Current Desktop, unless using a local virtual desktop.
Last updated
Was this helpful?
