Disable access prompt for Remote Desktop Manager when connecting to a Devolutions Cloud workspace
Some users receive a to grant Remote Desktop Manager access to their data every time they connect to a Devolutions Cloud workspace.
Solution
  1. Head over to File – Settings – Advanced.
  2. Check the option called Connect to Devolutions Account using Authorization Code Flow.
  3. Click Save, and connect to a Devolutions Cloud workspace without having to grant an authorization to Remote Desktop Manager.
Last updated
Was this helpful?
