> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/device-management-configuration-from-remote-desktop-manager-mobile.md).
# Device management configuration from Remote Desktop Manager mobile
Push Remote Desktop Manager mobile configuration files to other users iOS and Android devices using an MDM tool such as Workspace One.
{% tabs %}
{% tab title="iOS" %}
The Devolutions environment does not have a Mobile Device Management (MDM) tool to push the configuration to other user's iOS devices. But with the use of an application like Workspace One, it is possible to do so.
### Solution
1. Configure a Remote Desktop Manager iOS device.
2. Go to ***Settings*** – ***Advanced***. In the ***Mobile device management (MDM)*** section, tap ***Generate Managed App Configuration file (XML, plist)***.
3. In the ***Format*** list, select ***.plist*** or ***.xml***.
4. When asked whether to include your workspaces in the configuration file, tap ***Yes*** to select the workspaces to include, or ***No*** to export the configuration without workspaces.
5. Select the folder where the file is saved.
6. In your MDM application, use the exported MDM file to push it to all devices.
   {% endtab %}
{% tab title="Android" %}
The Devolutions environment does not have a Mobile Device Management (MDM) tool to push the configuration to other user's Android devices. But with the use of an application like Workspace One, it is possible to do so.
### Solution
1. Configure a Remote Desktop Manager Android device.
2. Go to ***Settings*** – ***Advanced***. In the ***Mobile device management (MDM)*** section, tap ***Generate app restrictions file (XML)***.
3. Select where the file is saved.
4. Select the workspaces to include in the file.
5. In your MDM application, use the exported MDM file to push it to all devices.
   {% endtab %}
   {% endtabs %}
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/device-management-configuration-from-remote-desktop-manager-mobile.md?ask=<question>&goal=<user_goal>
